Hello
I am getting the Lucid Charger installed in my Garage. The electrician said:
a) He will add a 100Amp breaker. Whole house Panel supports 200A.
b) He will run a #2 wire (of 35 feet) from the panel to a point in the Garage to install the charging station. This wire will run inside the drywall and not be in any external pipes.
c) He will adjust the dip switches on the Charger to select 80A and mount charging station on the Garage wall.
Once he installs it, I can start using the Charging cable that came with the Charger into it and charge daily.
Is there any thing else to be done in the installation? Are there any precautions I need to take?
